Suitable substitute for a DSC 5D-13 Thermister...
On Friday, September 23, 2022 at 5:40:13 PM UTC-4, John Larkin wrote:
> The real thing seems to be available.
aliexpress sells it:
https://www.aliexpress.com/i/2251832588177535.html?gatewayAdapt=4itemAdapt
I know, was trying to find something closer.
Still Martin is right, it is just a thermister. I just was wondering if
anyone had a better idea of what one to use as a sub.
John :-#)#
(Please post followups or tech inquiries to the USENET newsgroup)
John\'s Jukes Ltd.
MOVED to #7 - 3979 Marine Way, Burnaby, BC, Canada V5J 5E3
(604)872-5757 (Pinballs, Jukes, Video Games)
www.flippers.com
\"Old pinballers never die, they just flip out.\"
** You are making no sense.
** NTC * power* thermistors are remarkable components, like no other.
> I just was wondering if anyone had a better idea of what one to use as a sub.
** You are still making no sense.
....... Phil
I should have expanded, closer in the sense that the 5D-13 arriving in
mid-October via Aliexpress, vs a suitable sub from Digikey which could
be here overnight.
We did end up going the Aliexpress route.
OK, that is something I wasn\'t aware of, thanks!
Yeah, that happens sometimes to all of us.
...... Phil
John :-#)#
**FFS Google \" 5 ohm, 13mm NTC \"
Pick your dealer.
...... Phil
Pick your dealer.
..... Phil
Crap, you mean the spec was in the part number? 5D = 5 ohm, and the -13
is the diameter. Gah!
Thanks, wish the data sheet I downloaded from DSC had suggested that!
John :-#)#
Pick your dealer.
** FYI 5 ohms is the room temp resistance, while the size relates to the power dissipation.
A 5 ohm one will drop to 0.5 ohms when hot - typically about 150C.
......Phil
